Rocker boxes are in and done for the most part. Going to go back and clean up some of the welds still.
Insides were sprayed with a second coat of LizardSkin after all the welding was done. Endcaps I had to trim the bottom off and move it up some, not nearly as much work as I thought it'd be.
Everything is tucked up nicely behind the innner/bedside.
Sprayed a little more coating on some of the underside, mainly the areas that would be covered up by the endcaps or around them. I'll actually mask the frame off and tape it up when I do the main part of the floor.
With those out of the way, it was a toss up between starting on the outer rockers or the cowl panel. Decided to do the cowl, since that and the windshield frame will pretty much be the last of the real dirty metal work.
Couple shots of the problem areas before I started cutting. The first one isn't under the cowl, but it's close and I know it's hiding more under the silicone.
Nothing too bad so far. Can see the side I cut out when I replaced part of the firewall/A-pillar.
After opening up the drivers side. This is after the truck had been washed/blown out/vaccumed a bunch of times....this is the exact reason this area rots out. Note the angle iron rain gutter above what's left of the fresh air vent.
After sweeping it out some. Bottom is full of holes. Fresh air duct frame work is completly gone.
Passenger side is a little better (mostly because I already cut out a bunch of the bad stuff).
Couple minutes with the grinder and I had the old piece off. I don't think the blob of caulk is factory. Judging by the way it's applied, looks like they stuck the tube in the vent and pulled the trigger. Doesn't appear to have really done anything other than make a mess. Passenger side has the same thing going on above the air vent.
Small hole, I'm guessing what they were trying to plug. This is the one I found while pulling the dash appart.
Still need to finish pulling the other edge off, then I can get started on cleaning up the metal and rebuilding the inner parts.
The repop piece inludes the brace on the passenger side. So I didn't need to save the original one like I did. Drivers side had something on it too, but it was to rusty to even try saving.
