im buying a 1977 k5 with a 350/465/205. im putting the 465/205 in my 87 k5. my question, will the brake/clutch pedal assy work in my k5? will anything else be different?
yes, the pedal assy. will work. the question is are you going to want a mechanical clutch or hydraulic clutch? 77 will have the mech. clutch and you'll have to add a bracket to the frame for it to work.
I just did this swap, its like an erector set, drop the colum out take out the auto petals and swap in the manual petals. Keep asking questions cause I went through it the hard way.
