79bonanza
dang another piece of ply wood. i found a big rock to work on but hade to move back to the dirt. just couldnt handle such a high quality work area. lol
I want to pry that tab out away from the center axis of the post right?
Judging from where your notch is I'm thinking the flange is ok where it is?
What flange are you talking about? The one that the bottom half of the crossmember bolts to (the part that allows the crossmember and oil pan to be removed)? If that is what you are talking about NO, the angle of that part and flange aims the crossmember at the engine. If you are talking about the frame flange than yes. I expected to have issues so I had Kurt at DIY 4X4 send me an extra set of bushings, the tube they fit into, and an extra set of plates that bolt to the frame c channel.
Thinking about it more, even if the axle comes up at an angle it shouldn't hit. My rough thoughts for the cross bar is to go with a thick L or C channel shape to avoid the pumpkin. What do ya think?
If I was to do it again I would just use the motor mount bushing part and completely remove the crossmember until the engine was installed (these engines are designed as a stressed member and the newer trucks don't even have a crossmember but their frames were designed with this in mind). After installing the engine I would then make the new crossmember angled away from the pumpkin however I kind of like that my front differential would hit the crossmember instead of the oil pan. I am still considering a 2 inch lift for additional clearance but I have not hit. I also don't offroad it but the roads around here are kind of like off road?
What are the options for the oil pressure sending unit? I noticed yours in your photo album. Is there enough room to ditch the hose between the adapter and sender? Do you remember the factory sensor thread type/size?
Have you tried switching the crossmember the other way around to see if there is a difference? Might want to give it a try. You might need to move the crossmember forward in order to clear the firewall. I've never done one of these swaps, so i can't speak from experience, so i'm just taking guesses here.
