I avoided doing a lot of work on mine because I knew it was a good running motor with low miles. Don't know if you have that advantage or not. I always have this philosophy that I don't mess with stuff that's working fine if I can absolutely help it.That's good to hear. I backed off on a few more of my "might as well" upgrades and had to double down on some others. So I can use the extra encouragement that this thing isn't going to be a dog.
I was waiting on parts to put it back together. Then I ruined the cam bearings removing the cam so I'm waiting on tool to replace the cam bearings. Doing everything I can to resist the urge to remove the crank and pistons.
I was thinking yesterday, "Wow! This truck is fun to drive!" I guess I just hadn't appreciated how doggy the other motor was. Plus it blowing oil smoke everywhere on startup. I need to replace my rear seats with a bench seat so my dog has a more comfortable spot to ride so then I can drive it to work more often. He likes to lay down but he's too big to lay in a bucket seat.
The Newer BBC's are like that now from the factory, but a .030 hole is spec on them.
Decided I'm going to keep the TBI system for a while at least until the motor is broken in and get some summer fun in. That's puts a lid on the cash flow as well. Just not sure if I should get a bigger throttle body or just try and run the one I have.
A stock 2wd fan shroud should work.
