You guys are so far ahead of me mechanically, its not even funny. Keep up the good work, I'll be interested to see what kind of mpg you get once its all buttoned up.
Some light reading in case you haven't already been warned about the seriousness of the TV cable setting.
http://www.tvmadeez.com/article/index.php
It's NOT a simple kickdown cable like on a TH350, and the adjustment is critical or you'll burn up the new, expensive transmission.
Also, it might have been Bowtie Overdrives that developed a custom TV linkage that allows you to install their setup, floor the gas pedal once to establish full-travel and the TV cable automatically sets iteself based on that throttle range.
I don't know if that solution is "real science" or just a bad idea, but it sure seemed like an elegant solution compared to the traditional methods for setting the TV cable.
Oh yeah...and to clarify the machining on the rear yoke... about 1/4" need to be taken out of the diameter not the length. For anyone doing this in the future, take the 1310 yoke that comes with the SYE kit to the machine shop along with the 1350 or 1410 yoke....it'll help explain what you're trying to do.
. I'm also working thru a slick cable shift idea in my head...we'll see how that pans out. For now, I'll have to crawl under the truck to shift it. Oh well....
