Wait you sold the AMG???
Yep... a couple months ago.
With all the money I'm saving in maintenance, I could probably build a really cool 4x4.
-G
Tits!I have no idea what your doing I just got lost and well, was thinking about some tig bitties, is it time for bed yet?
How do you weld the last tube to the collector?
Looks like some nice forms for 40 mini burgers.
Yeah, the fat guy is hungry.![]()
It's just a slip-fit into the head flange.
The exhaust ports are square, but for now I just tacked a temporary 1-7/8" round tube inside it. I didn't bother to dolly it to match the port shape, I'll do that once I'm building in the real stainless material.
-G
Pretty sure he's talking about the COLLECTOR where all the tubes come together and not the FLANGE at the head.![]()
Have you started playing with the Dynasty on Stainless? I'm interested is reading about the learning process of welding all this together.
-G
2015.06.22 - UPDATE! - VORTEXES OF SPEED..!!!!!
-G
I see what you want to do here, but a MUCH easier way is to try to make as many bends as possible out of pre-bent angles, like 45"s, and do the welding in the straight sections. Those headers you had hanging on the wall are a good example. Mandrel tubing is supposed to be consistent, ie round, but the reality is that the tubes sometimes flatten out a small amount when bent. It isn't a big deal usually, but can really cause problems when lots of your turns are welded through the bend. The key to a set of great looking headers is PERFECT fit up. These headers will be in everyones face, and you cant top off years of work with a less than perfect result. Given your OCD everywhere else, I suspect you will have hundreds and hundreds of hours in these and still not be happy with the results. I would reconsider and try to make them easier to build. YMMV
He's just using these parts to visualize the result. Once that's done he's going to piece a new version together out of stainless.
Brian,
I think what he's saying though is to try to simplify the design so that I don't have to do so many custom offset angles which will be a lot tougher to weld.
At this point, it's still too early to even know WHAT is possible for a design given the space I'm working with... so I'll just keep plugging along until I can at least render SOMETHING, then I'll figure out if it's a design that is practical to build.
-G
