bp71k5
3/4 ton status
It's the brake booster wire or the gas gauge lead. Forget which.
I begrudgingly took photos of the tear down, but not NEARLY enough of all the little details....
Now the decision becomes whether I want to keep all the wiring EXACTLY to the factory spec.![]()
I hope to confuse people at BlazerBash with that...Because your truck is going to be to so close to stock
-- A
I got my factory assembly manual out last night to check but couldn't get through it. Did you look there?
If you decide to not use the factory glass tube style fuseblock, my ATO fuseblock had space for extra wires to pass without needing the extra holes. I suspect most of them do.
. Not surprising, that book is it's own kind of special torture!
-G
for what it's worth, I have both of those support rods still, but can't use them with the hydroboost (gotta fab up something new). if anyone needs them I'm sure they'd fit on a flat rate box...Mike,
I noticed that your brake booster is missing both support rods.
Plus, there is an awful lot of wiring behind the dash that will remain unchanged (turn signals, headlights, gauges, ignition, backlighting, HVAC, etc) I'm not sure I want to swap all of that out....
Buddy,
Thanks for that... I couldn't find the images on the AAW catalog I downloaded.
There's still time to figure out a wiring strategy. I think I need to map out EXACTLY what extras I plan to add to the truck and then work backwards to build a harness to support it. Maybe a factory harness for the majority of "stock" items, then a small aftermarket fuse block for the stuff like EFI, offroad lights, stereo, etc?
Anyway..... It's a cold, icy day here in New England. Seems like a good day to fire up the wall heater in the manspace and put a bit more structure on the engine cradle?
-G
