2012.08.18 - UPDATE! - A "QUASI"-HERO DAY.... !!!
I am pretty strict about the use of the term "hero day", and I don't like to throw that term around unless something really substantial has happened with the build. So, for today's update I will only give myself a "quasi" hero rating for the forward progress...... the actual parts added were small but it is leading quickly to more meaningful steps in the very near future. :waytogo:
First of all, let me give you a little taste of how things work around the Greg72 household when it comes to "garage days" (aka The ManSpace)..... this weekend, I wanted shop time so I had to trade a day's work on the house for a day of K5 stuff. The latest project is tearing off 60-year old siding and tarpaper and replacing it with fresh Tyvek and new cedar siding.
I chip away at this stuff for an hour or two most weeknights, and spend a full Saturday on it. As anyone who has ever installed siding knows... the work is a lot faster up to about 6' high. Once you have to climb ladders to pull measurements and nail up siding it gets a lot slower. :D Anyway, I got this wall completed by Saturday evening, so Sunday was all mine!
The shop was clean when I started my day. That's a good feeling. Usually I have to spend about an hour cleaning up residual messes that have accumulated throughout the week but I managed to get all that done on Saturday... I was able to roll up the doors on a sunny morning and see the truck just like this:
(You can see the blocking under the rear tires in these photos. This allows me to level the truck and frame, even though the cement slopes downward toward the rollup doors.)
Time to dig in and get some more "pretty" brackets built to finalize the front suspension....
Here's the start of the DS lower link mount bracket. This heavily leverages the design from the PS bracket, but since there's no pumpkin on the DS to anchor to, things are going to get a little different.
One of the areas where things changed was the way I created and angled link mount but still preserved a good flat upper mounting plate for the lower strut mount.
Basically, I created the angled mount that I wanted, then built one additional plate that would "square off" the area. The real trick is to make sure that all of the existing bolt holes can still be accessed afterwards. so I had to get clever with my annular cutters in a few spots, and also make sure the brackets left small gaps for wrenches, etc.
Once the bottom plates were all in place and burned-in, it was time to affix the upper plate. I thought it would be overkill to drill a few holes in the plate directly above the 3/4" thick CNC adapters and puddle in some nice hot plug-welds in addition to all of the other normal perimeter welding I'd be doing...
Here's how the bracket looks from the front of the truck. This speed hole isn't for bolt access...this one is truly just for SPEED! :haha:
For comparison, THIS one actually is for bolt/nut access... This gets a socket wrench in to tighten up the lower link mount bolt when the time comes....
Time to add some more "overkill on top of the existing overkill".... I welded the 3/8" thick strut mount base with plug welds to the 1/4" plate underneath it. It will get fully perimeter welded later on when I pull the axle and get it up on my workbench for all of the final welding processes.
Shortly after that, I took one of my existing 16" struts and collapsed it down to 4" of exposed shaft (This simulates the eyelet spacing for a 14" strut at 6" of stickout), bolted the mounting tabs to the lower mount, wrapped everything critical with green tape to protect it from welding spatter and then laid a few heavy tacks on the tabs to lock them down to my new strut/lower link mount. :waytogo:
So there you have it.... not a TON of progress, but the fact that the struts are starting to find their way onto the truck (and are starting to hint at the type of upper mount they are going to need!) I'd say it counts as a quasi-hero day....
-G
Eh, I'll give ya a Hero Day bump, man. :D
Awesome to see some welds actually happening on the axle. In the back of your mind, you must be getting a lot closer to victory. :saweet:
ps. Your secret box of four ______ should be packaged today. I'll see if I can get it out tomorrow. :waytogo:
I'm with Mike. Final welds in the thick stuff seems like hero day material to me! Well done sir! :bow::waytogo:
Here are a couple of quick images as I think through the upper strut mount strategy....
Front View:
The first part I'd add is a bar across the firewall to strengthen the existing engine cradle bar laterally. A small bump in the center of the bar would give me clearance for the dizzy and would allow me to keep the ends of the bar lower and in the same plane as the engine cradle. This should make is simpler to build my strut tower from these bars.
I would also re-install the diagonal braces (which have been in earlier photographs in this build) to connect those upper firewall plates down to the top of the framerails on both sides. Basically this bar runs very close to the firewall and starts to triangulate things in that area for strength.
Top View:
Another triangular bar runs from about the mid-span of the engine cradle back up to the firewall area to define a "triangle" shape that is all in a single plane. Somewhere inside the boundaries of that triangle is where the upper strut will ultimately land.
Additional bars can be brought down to the framerails from each of those remaining nodes (one is shown in the image above from the mid-span to the frame, the other was left off for clarity in the front view)
That's the basic concept I have so far... I posted up in the "Desert Truck" section to try to solicit some good resource images to study..... :deal:
If you've got anything cool and relevant (coilover type mounts) post them up!
-G
Pretty much already concluded that I'm ditching the factory vacuum boost setup for a hydroboost unit. They are a LOT smaller and easier to package, but I will need to stay focused on that "through hole" in the firewall as an indicator of where I need to reserve some space. Same holds true for the steering.... I'd like to save the stock column for simplicity. If I need to build a crazy set of flex-joints to actually connect the steering box to the wheel, I'm OK with that.
For the purposes of discussion, we can assume that I've got clearance everywhere I need it..... the small, fine-tuning of tubes and their positions will reveal itself once I start trying to render it in actual metal. :thinking:
-G
VintageAir :waytogo:
I temporarily gave up on A/C when I was building my front axle and the upper link mount blocked the spot where the A/C compressor needed to go. However, once I moved the axle back a couple of inches and reworked the bracket it looks like there is room again to get that compressor and pulley down low on the PS of the motor.
As you probably know, the VintageAir system relocates everything under the dash pretty cleanly. Nothing actually bolts to the firewall on the engine side, so it's pretty stealthy.
Good catch!
-G
Gotcha, yeah I was going to say, you have come way too far with this build to not have air conditioning.
Martin
Why would you have AC in a topless truck :screwy:
I rented a Jeep Rubicon in Moab for the last BB event I did there..... Topless with A/C was NIIIICE!!!
Sounds weird, but it really does help.
It's probably a combination of blowing cool air onto the floorboards to counteract some of the radiant heat coming up from the exhaust and transmission, as well as the dash vents putting just a hint of coolness into the ambient air in front of the windshield. Remember, at 3MPH (or less!) crawling on rocks it's not like there's a ton of air rushing by to cool you off, like there would be on the highway.
-G
By the way....just noticed that you lunatics just pushed this thread over the 400,000 views mark! :yikes:
I remember thinking it was crazy when it hit 50,000. 400K is just nuts.
-G
I've been watching your truck on here since 2001. Too bad you don't get a nickel for every view you get. That would help you with build costs. Lol. Good to see you getting some final welds and brackets in place. Your metal supplier must love you.
That reminds me.... I am just about out of 1.75" x .120 wall DOM
Crap.
Need some of those nickels. :D
-G
I don't post up much, but I know I've been driving up the view count. I'm always amazed when I see progress here, no matter how big or small. Far beyond anything I could even consider.
