2015.06.08 - UPDATE! - KILL DRILL, PT.1... !!!!
OK, OK.... it wasn't a drill, it was my angle-grinder that died. It's hard to find a good rhyme for "angle grinder" that makes any sense for a build title though.
Looking back, I think this is only the 2nd angle grinder that I've killed on this 7-year build so far (both Craftsman).....Hmmm, coincidence?
At least I took the opportunity to move upmarket a bit. This one should last me to the end of the build for sure.
So with new tools in the shop (I had to buy a new AC Cord reel also, since the plug got so worn out nothing would stay plugged in) I dug in on Sunday morning for some additional work to complete the rear strut hangers.
First step was pulling off the other tire/wheel and letting the suspension fully droop-out, so that I could get easier access to the lower brackets.
The tire clearances all seemed pretty good, so there really wasn't much value in continuing to cycle the suspension with them attached, and it just makes everything a lot heavier and more difficult to work around. With just the portals connected, I was able to really stick my head in there and look for signs of trouble...
As it turns out, I did actually have more work to do. When I started to stuff the driver's side the lower Schrader valve got close enough to hit the outside of the bracket. If left unchecked it certainly would have broken off and damaged the strut, so I'm glad I went slowly and checked things in small increments. After a series of unbolting the lower strut, grinding and reshaping the bracket, and re-installing the strut I finally was able to get to "full bump" on the driver's side.
The lower brackets were still only a single-shear connection for the early mockup so I still needed to cut a plate with a DOM sleeve to sneak inside that pocket. I also needed to make sure I left drainage areas for water and mud... and as I've mentioned before, bolt access for the portal backing plate was a bit of a challenge in a couple of spots, so the lower brackets also needed two access holes for those as well.
Once everything was clearly marked I cut the spot welds off the axle and removed the entire bracket so it could be fitted up with the extra material and then fully-welded (inside and outside) for strength.
After laying down some welds at 22.6V for a while, I had this:
The end result came out nice. I was able to reinstall onto the axle with a lot more welded area (not completely finish-welded in place yet but close!) so the bracket will be able to hold the fully weight of the truck now.... and I was careful to modify my paper templates to accurately show all of the small tweaks that I needed to make for clearance.
..... I spent the remaining time last night transferring those new template patterns over to the PS bracket and did some finish-welding on that one too. Hopefully tonight I will be able to get that bracket back onto the axle permanently and then turn my attention to finish-welding the upper mounts on both sides.
If things go well over the next couple of evenings, I should be able to get this truck standing under it's own weight before next weekend!!!
-G
