ENGINE: Needs custom exhaust manifolds. Stainless or Mild-Steel? I've got TIG now so I can do either one. I want a heavy wall tubing since it will resonate less, but I also intend to Jet-Hot coat the final product so it sort of seems like a waste to build with stainless... though it will last longer. What grade of stainless is best, 304? Sources for U-Bends, collectors, and manifold flanges?
Needs a fuel tank. I was thinking aluminum.... I hear stainless is too brittle and can "kill you to death". I don't need that. What grade of aluminum? The tank is going to be MASSIVE!!! I measured it out last night: 48"L x 28"W x 6" deep is 34.9 Gallons... if I go about 1" deeper I can get 40 Gallons. That's about 250 Lbs of fuel weight so I think the tank will need to be internally braced to prevent sagging or rupturing. I was thinking about using one of those Holley Fuel mats to prevent fuel starvation, and external pumps for easy servicing. I've read that the Gerotor-style pumps are super quiet so I don't have any concerns about keeping the pump out of the tank. I wanted to run two pumps in parallel with a Y-splitter effect so that I can have an easy failover if a pump ever goes bad. I'm not sure if fuel pumps are designed to work like that (one pump sits, one pump is working) without having the idle pump leaking fuel out backwards from the pressure???
3rd Members for Axle - Ford 9" centersections. I was going to use a Nodular iron case, and since it's flipped I need to use the pinion oiler (slinger) too. I need to run the 2.47 Ford gearset which is impossible to find NOS... so I'll have to buy them used. Any recommendations for a builder? Currie? Strange? Randy's? Oh, I'll need an ARB too.... 31-spline so I don't have issues with the RD-99 breakage of the 35-spline unit.
Transmission - I've got a 4L80E case, but it's just a core. I figure a quick call to our own Greg Ducato should be all that is necessary here!
Induction - Still thinking that the Holley Dominator is the best choice since it controls the Engine (TBI) and can also run the 4L80E as part of the same integrated solution. It's expensive, but what isn't on this build?
-G
