As always, this build makes me shake my head at how dedicated you are to building EXACTLY what you want. So freaking cool Greg. [emoji144]
This guy once described my build as:
"...attention to detail combined with near-retarded levels of awesome..."
I felt that was a pretty apt description....
Ultimately "I want what I want" and I'm stubborn enough to work and fight for as long as it takes until I get there. That recent quote from Jesse James on FB about never accepting "good enough" really says it pretty well also. It takes a stubborn and disciplined guy to build for more than 7 years without getting any sort of payoff.... and I've still got a couple more to go before any of this work pays off in the traditional sense. Of course I've said many times that "the process" of building is something that I get a lot of enjoyment from, and I know a lot of guys just don't
GET that...they just want their truck to be FINISHED so they can go back out and drive it.
First off I think the headers are looking awesome, keep it up! They look saweeet!
I do have one question, are you eliminating that square tube right behind the collector? Because it looks like it is right in the way. If you plan to use a large pipe radius there, keep in mind the bend radius of a large pipe is huge compared to the bend radius of the small tubes. Also, the collector takes up considerable length. You might want to get that collector figured out before you spend too much time routing the tubes or you might have to start over.
Heath,
That 1x2" block is just a spacer to keep the collectors away from the floorboards. It gets removed once the mock-ups are completed.
Good point about the bend radius for a 3.5" collector! It's going to be a tight-squeeze getting the next section of exhaust through that tiny cab-support area (I'd say it's probably less than an Oreo's worth of clearance....maybe a Thin-mint or Lorna Doone?), but I think I can do it... I have some flexibility to slide the actually merged-collector part up a few inches if I need to so that the bend in the 3.5" tube happens in a clean part of the tube instead of where all those 1-7/8" tubes are getting crushed together and reshaped into the large single exhaust outlet.
I'm so stoked about getting that 4th primary tube in tonight.....I can't wait to see it!!!!
EDIT:
I think you might have been asking about the 2x2" square tube.... here's the diagram of how that needs to resolve itself:
It's going to be tight. That red circle is the "through hole" for the collector, and the yellow lines define the rockslider / A-Pillar mount that is not moveable. I might be willing to put a small cresent notch into the top if it ends up being necessary, but obviously I don't want to do too much to weaken it structurally.
-G
