There is a lot going on under there.
Greg I'm seeing a couple problems.
First off with the exhaust coming straight out the back all your exhaust fumes are gonna get sucked into the truck. Really common problem with guys who have jeeps. But I have seen it plenty on other trucks like broncos and blazers too.
With the exhaust straight out the back your gonna be smelling it all the time.
and then the greenies can be happy while you drive on their precious dirtWhy not just convert the whole thing over to solar over electric and maybe a hydrogen generator in there too and you won't even need a gas tank or exh hahahaand then the greenies can be happy while you drive on their precious dirt
What happened to BB18 if now you say Charlie has to finish this?????When I'm dead and gone, Charlie will need to take this build forward with his own ideas and creativity.... the technology will certainly be more mature and accessible.
Never say never.
-G
I'm just talking about moving that crossmember that the tank is butting up to.
I would imagine you might only need a couple of inches to hit 30 gallons plus. It could still be a very square tank.
The more I think about wheeling and what I have hit and seen others hit the less and less I like the saddle tanks. If you take your total amount of seams adding a taper in the center tank vs 3 tanks is substantially less seams. In addition to hoses vents etc on the 3 tanks.
I know most consider your build complicated but I look at it a little different. I kind of look at it as the best way to come to a good solution. Some things might take a ridiculous amount of time to perfect but they are really a simple solution. Your wheels being a perfect example. There was a stupid amount of time but it really is a simple solution to a problem. Sometimes simple requires way more work
Dude... just run one center tank and be done with it! If you need more fuel for some reason, carry something like this on extended trips.
And if it's a really long trip add one of these.
I think folken has the right idea. Make one large tank notched for the framerails. Sacrifice some of the front edge for the exhaust (you'll regain some running under the framerails) and run the exhaust behind the tire.
There has to be a much simpler solution to this problem. Where else can you position a tank in the truck? Even just as a transfer tank. What kind of range are you after? I cant imagine with that motor you getting much better than 10mpg?? Even with 30 gallons you might squeak 250 out of it?
I think folken has the right idea. Make one large tank notched for the framerails. Sacrifice some of the front edge of the saddle tanks for the exhaust (you'll regain some running under the framerails) and run the exhaust behind the tire.
