Rear electrical issues
So like I said, this little teardown started with some electrical issues. Turn signals stopped working a while ago, figured it was just a flasher relay. A tail light went out before I stopped driving it, and thought that was a bulb or possibly some funky wiring (have had issues with the rear wiring before).
Trying to diagnose the problem, observed the following at the rear:
- tail lights came on when headlights were on (as expected)
- turn signals weren't working at all
- no hazards either
- brake light worked on right, but not on the left.
First tried all the obvious things: fuses, flasher relays, and bulbs. To my surprise, no change, BUT occasionally the single working brake light would switch between the left and right side, but it was always just one side working at a time.
Next thought was that there was either a short or broken wire somewhere, so I started testing wires and sockets with a multimeter. Everything seemed to check out, nothing out of the ordinary.
Next: PO had hacked in some shoddy trailer harness wiring thought that might have been goofing things up and also wanted to get a closer look at the wires in the body, so I ripped out the rear wiring harness. The lighting assemblies were already out, so it wasn't much more work to get the wiring out to have a closer look. With the harness out, I decided to remove the remnants of the trailer harness for good measure - not towing anything anyway, already ditched the hitch.
Upon inspection and more multimeter checking, almost everything was alright, although the RH marker socket was missing (added to list of new parts), and the license plate wire was separated. Neither of those things were causing my problems, but worth fixing anyway.
Here's the LH marker socket that's missing from the RH (circled):
and the sad, lonely wire:
