73 K20....crossmember time
I have seen the goofy "w" shaped crossmembers before but every truck I've owed has had the flat style crossmember. I didn't know they were due to different height adapters. I guess I've always just lucked out with the ones I ended up with. Is there a reason behind the two different height adapters?
Same here I've only seen the lower crossmembers. Never seen the tall one I even in person.
To a point. If it really didn't matter we'd be flipping left-handed 241 cases over to fit our right-hand trucks.
Right. The bottom must always be the bottom. Oil pumps at top don't work too good.
The tall adapters were used from 1981-1984, the short adapters from 1985-1987('91).
Martin
Worked on the special socket today. Only 1 minor interference to deal with and it's done.
Found some giant channel locks and actually got the nut off, which is cool because I can make sure it actually fits the socket. It does.
I saw a torque spec of 110 lbs on this nut so it's obviously not going back on with channel locks. Hopefully I'll get it right tomorrow.
Damnit. This whole missing part game is getting really old to me. Turns out there's no pushrod between the hydroboost unit and the master cylinder.
I can't seem to find it either. Gonna check lmc.
PnP more likely. Or you can fab your own ... it's just round rod with sphered ends. I think it's 1/4" OD, but length is of course critical. I'd offer to measure mine, but I think you got the later ('88+?) setup so it won't do any good.
-- A
-- A
I'm thinking so. I'll have to go in there, peel one apart and pockets the needed parts. Shouldn't be too hard. Seems like it just slides in.
I went with the 87 setup. Not sure why but that's what I got.
I'd make it but the problem is that goofy looking washer.
Ohh, the washer is a spring, yeah, holds the rod in place.
If you can't find one @ the PnP, lemme know. I'm moving this weekend, but mid-next week I can pop my master off and measure the pushrod for you.
-- A
-- A
Cool thanks! I thought you already moved!
