Is that from the heater core?
Now you know!
Depends on why they're foggy!Foggy windows suck.
Martin
Hungry yoke?
Go get a good battery.. nothing worse than screwing around with a crap battery.. trust me I killed mine then the starter just out of pure bad timing. Sounds like you have bad luck too.. charge it and keep it charging while your beating on it.. maybe jumper cables on there to when your messing to keep it topped off
Hungry yoke?
low voltage will create all sorts of problems with the fitech system too.
Don't burn it up..
Me leaves the hot wire off until I'm good and ready. I did start welding the valve cover when putting the lead on the alternator the other day hahaha
