I use a stock poly mount for the trans adapter, works fine.
The ones that are slotted? Mine fit in a channel with a slot on top which the poly keys into.
Commies...Photobucket has gone extremist. All the pics are blurred now unfortunately
Photos in my thread work...Photobucket has gone extremist. All the pics are blurred now unfortunately
Using the 3 on that plate above?I think I went through yours. Cant remember if I found them.
What do you think about only using 3 out of the 4 holes for supporting the 205? Should be fine eh?
Read the other link in that doubler Sticky. Stephen had input about t case mounting that’s relevant to your causeCorrect. No midplate. Apparently with the shorter blackbox it's not needed. That's what I've hear anyway. That 32 spline 465 adapter is pretty solid.
I’d still prefer 4 bolts, but use grade 8 hardware if not
I wouldn’t hurt your brain reattaching that. Pretty sure I remember you adding new mounts on everything, it should move as a wholeI think I cam reattach that 4th pretty easy. I need a longer bolt then I'll bolt it all up, add a bit of steel and tac it all together.
I'll check that out. I've been meaning to get the dimension of the cases to add to the sticky. Being that I have a titan shaft blackbox it's super short.
