remember those caps are held on with a seal so that's likely the reason why it won't budge. I've had to soak them and tap them with a hammer in the past and they would always break loose for me. Getting the studs out can be a real bitch but that's not necessary at this point. Heat is an option but it may damage the kingpin bushing
Just try not to pry and f-up the knuckle to cap sealing surface.
If so that's your issue..... Chevy's came 8 degrees POSITIVE and Dodges were around 2 positive
