wetoolowdingbangow
I thought that until my truck wouldn't get above 30MPH without turning into a bucking bronco, err, Blazer.
-- A
Yeah but it cant get worse then it is. ill 4 link it in winter lol
-- A
I think only our fellow Californians are going to get that one.
I think that is the general nick name across the country.
Martin
Looks good!
I'm curious (and maybe I missed it), but why did you mount the front shocks like that?
I did the same thing as a tech article explained on here but it isnt perfect. I really want them up and not so laid back but itll have to wait a bit. they seem to work fine there but where I wanted them there was that bump in the frame so I had to set them back. Its like anything else it has revisions needed
plus you moved your axle forward with the zero rates after mounting the shocks right? I ran into the same problem so I'm moving them vertical soon.
Exactly. So that made thing a bit worse but in all reality im not going across the desert at 100 mph so its not the end of the world.
Well i called 4wheelparts and the tires i wanted (toyo 40s) are on friggin back order
It could be a month or more to get them so im looking at other options. I know someone who literally just got some of these tires and now there are people waiting in line to get them.
Im going to check if nittos are still back ordered...
Why not the new pro comp MT2's?
I can get the pro comps tomorrow. im thinking im gona swoop those up...they seem to be good tires. Ill put them through the ringer so we'll see!
I'd run them![]()
Its not Toyo's fault that every single bro-dozer in Cali MUST run 40's. If they didn't their hats would get droopy and their 80's sunglasses would break.
I'd run them![]()
I think im gonna do it. I keep reading good reviews about there 37's because they've been out longer. I also have seen several times that their made by maxxis.
Yeah maxxis makes some good tires so im doing it! I have 4 with my name on em at 4wp.
