Time for an update!
Ive been working on this thing like crazy but im making real good progress so far. I found out when I was bolting up my disc adapter kit for the rear end that it is a bastard axle. In other words its different than the normal 14 bolt ff thats used. Its all the same insides just a narrower track width, shorter spindles. My research confirms that it is in fact whats called a 2nd generation 14 bolt. Its still a truck axle but its newer than 1985 which was what I thought it was due to the ring gear stamping. So as usual I had to adapt and over come. I sold my disc adapters being that they didnt fit and got some weld on ones instead. I welded some ruffstuff brackets on and they work great! I then bought some .5" 6061 spacers to bump my WMS measurement up. Seems like itll work just fine.
Ruffstuff weld ons
Got it rigged into place so the slide bolts were able to clear whatever is behind them.
Bought cheap pads and received good ones? Never seen this before but i was happy...
Got my shackles on as well. I ended up removing 2 leafs from each side due to being too stiff and it was riding ass high.
Shes a mess but its crunch time! Brakes are now bled, just need to tuck the lines up and out of the way.
Started preparing for hydro assist. Steering box is done, starting to weld tabs to the axle housing.
Trying to find a good spot for the heatsink. Hesitant to drill near hardlines so i may take the windshield fluid container out temporarily and relocate it.
More prep. axles are back in. Gear fluid in with no leaks.
This guys ready to go on tonight.
Decided i wanted a clamp for the hydro assist. Didnt want to pay for one so i made it. Probably still going to tack it on because it would be crappy if it slipped on the trail...
Got my dirt shovel on...
She lives!
Im attempting to put my locker in the front now, which may not happen due to a seized roll pin. Then ill put the hd diff cover on, finish the hydro, take it for some test drives and start sliders. After that its "done". Ready for the Rubicon!
