so I got a little more information on the 383 I am looking at and the roller cam is a .528/.536 lift, 221/226 duration and 110deg lobe separation. it has a 750cfm carb with 10:1 compression ratio and makes 350ft/lbs at 2000 rpm and about 400 and up past 3000rpm. gotta do a little more learning to see if i will make enough vacuum for the brakes and pick a correct torque converter but i'm getting close to ordering
