NorCalKid submitted a new Build:
'73 k5 Build - New Drivetrain - 350/3500/241/205
Read more about this build here...
Been getting a lot of stuff done on my k5 this winter break so decided to post up my progress.
Almost done converting to 1350's up front. I swapped in a 32 spline ford shaft in the 205 for more yoke options. Made a square drive shaft with ttb50 axle shafts and some 1/4" tube. Just need a 1350 yoke for the 60 (should have one tomorrow).
Finally got tired of the ****ty ride from the cheap springs so I built a shackle flip for the rear with some leftover steel from the drive shaft. Pulled every other leaf from my 56's and ended up with 3 and the overload. Threw on some 7.25" shackles from Kert and she is sitting about .5" higher then the old springs.
While I had the axle out I welded the spiders up (the right way this time) into a little orb of traction. I also threw on a diff cover from Kert, an unwelded flat, my welds aren't as pretty as Kerts but they got good penitration. Gave it a little shave too, not too much just smoother the lip.
In the front I pulled the bottom leaf from the lift springs and put in a degree shim dropping it down .5" from before. Threw another of Kerts diff covers on there too. Hopefully tomorrow I will get a yoke for the front blead the brakes and flex it to measure for shocks. Probably end up inbording the rears somehow
Ended up chalking all the tires and eventually broke it loose.
