I'm betting the new factory hold down is right side up now...
Rene
Rene
Just get a column at the junkyard. I found one one with a key in it and it fixed all my cruise/wiper/light issues easily.
.I'm betting the new factory hold down is right side up now...
Rene
What are the dimensions of that box (length and width)?
Sorry this took so long, I just remembered and ran out to get these for you: 57 1/2" x 20 1/2" on the lid.
Knowing me, since I am thinking about getting a box now, it will be 6-12 months before I actually do.
That way you dont have to take it to some shop to get timed again. On mine i just put a dot on the cap above were the wires go underneith it and a dot on he intake straight across from that.
If i were you i would mark a dot on the distributor and a dot on the intake so you know where it is set just in case it gets turned again.That way you dont have to take it to some shop to get timed again. On mine i just put a dot on the cap above were the wires go underneith it and a dot on he intake straight across from that.
Had a problem with my distributor being alittle loose this weekend and had to tighten it down and i was thanking myself so much for putting a mark on it![]()
Best deal I could find on an all spring lift when I ordered mine was 4" Rough Country lift through top gunz customs. Has everything you need and your current d-shafts should be fine.
http://www.topguncustomz.com/Store/Gen2ProdDisplay.php?iview=250127973
i'd piece a kit together thru ORD... Stephen'll hook ya up with everything ya need for a good working 4" setup...
). Plus the fact that I'll have a hard time calling during their office hours b/c of my work schedule.You might try the texas4x4 classifieds, probably could get what you need there fairly cheap and local.
I know most people will tell me to ditch it, but I'll want to drive it to see how much of a difference it makes.
