StevoandaRedK5
Then try it and see how much difference it makes.![]()
People tend to default to the anti-swaybar position, but every truck (and driver) is different. With the ORD discos, you will eliminate the binding (even when connected) that causes most people to ditch the swaybar. A used set of discos shouldn't set you back too much. Worst case, resell the discos.
"ray" on here lives in Austin, seems like he had a set he was selling. I bought a set off another member here for 35 shipped. Figured I need it to help with the 1000#'s of gorilla on the back.
Thanks guys. I like the idea of controlling the body roll on the street, and I know it works in it's stock form. I'll try to find a used set, or just pick up some new ones. It'll be worth it in my book.
I was hoping that I'd see a post like this from searching, I know Chalet is running it. Just helps reassure me that it'll work and have what I need. Thanks!
. It's was running fine, hit WOT to merge last night cause of a car in my blind spot, and then the idle went to crap. Front blade(?) on the carb sits way open and is giving it way to much air at idle i guess. When I lay into it and it gets more fuel, it'll throw me back in the seat. But idle-to-off-idle throttle response plain sucks.
