Like a big block project Dean.![]()
It`s funny how excited Colby is about it!
Even Kate is calling it Ratbag already.
It's sitting on the living room floor to unkink the folds. Then I'll have to figure out how to weasel the thing into place without tearing it. The cage feet and the triple stick will be challenges.
Not sure how your weather is, but I found the sun to be your best friend when installing flooring. Let it get nice and hot and then its sooooo much easier.
You gotta link, or PN, Arron?
I couldn't find those on their site.
You must be really amped getting that wiring fixed.
Sorry, I couldn't "resist".
....such easy comedic fodder.
If you wanted to indulge your CDO tendencies, I'm sure there is a way to pre-wrap the wire with a small piece of blue 3M tape, then paint on the liquid electrical tape..... And remove the tape before it sets permanently to reveal a nice crisp edge.
Of course you can still indulge other neurotic behaviors like measuring precise intervals between the zip ties that bundle the wires together (with machinists calipers).....making sure that the zip ties all face the same way (zip tie passes through either facing you or away from you, but always the same way), and try to line up all the slots on the screws to face the same direction on your buss bars...... You know, fun stuff like that.
Just be sure to leave enough of a "service loop" in your wiring. It's great to keep everything super tight and neat looking, but it can make it a nightmare to service later on when there are more parts in the way and it's not quite so easy to get your hands and tools into the area.
-G
But yes, the relay assembly comes out and away from the fender for servicing easily enough.
but it was definitely more exciting than usual on the highway.
Painted and bolted in place:By "Emu's moving and stowage", no, I don't mean I'm getting a new house, not for some time yet. Of those two things, first up, for those guys talking about the weight of a 14-bolt, note that they do change your center of gravity.
This weekend I brought home a C&C 14BFF for the sixpack (which is in pieces or else, like a sensible person, I would have used said sixpack.) The front of the Blazer wasn't exactly floating, more sort of semi-floatingbut it was definitely more exciting than usual on the highway.
And yes, that's one of those steel cargo trays that hook to the receiver, but the axle is chained and strapped down and the tray is then strapped to the truck to keep it from wiggling. It actually rode very nicely, save the fact that I had five or six hundred pounds that far back.
-- A
What did you need to axle for?
Ah gotcha. Seems like the caddy disc brake calipers just aren't what they are cracked up to be.
Random factoid:
-I read in an article a good dozen or so years ago that one of those axles combined with SRW hubs and brake parts would make for a Jeep/small truck width 14FF. Mentioned that in passing to a guy I knew with a pretty big Ranger that was blowing up axles pretty frequently.
Next thing I know (literally within a month) he's found the only C&C dually 14FF in the state of Ohio, has it converted to SRW, and has it under his Ranger on 38's. He had no more rear axle breakage.
