Y'all kinda challenged me with the commentary about the wheel covers blocking the front hubs. While I still don't think it's a big deal to remove the covers on the rare occasion I actually engage the front axle, I put on my thinking toque to find a way to implement the suggestion of the spinning bowtie logo.
First I cut up a spare cover, and discovered the hub dial is actually pretty close to the surface. I had to destroy the bowtie logo decal to get it off, which was a very nice metal piece (more on this in a minute.)
At first I thought I'd go down to the local plastic place and get some acrylic discs to fit in the cover, and then use PVC pipe to drive the hub dial. As I considered how to make it strong enough to withstand the torque required to spin the dial, though, an epiphany struck. I can 3D print the parts I need! So I broke out the trusty CAD program and after a few iterations ended up with an inner piece to drive the hub dial
This piece goes *inside* the wheel cover, so the cover holes it against the hub dial. The two semi-circle things on the left fit into the hub dial and the star shape on the right mates to the other, outer piece...
The star shape is basically an eight-point drive. Consider it the ARP fastener of plastic
The two pieces are actually glued; this particular plastic can be glued with the same stuff you use for acrylic. The glue keeps the inner and outer pieces from popping out, and the eight point shape transmits the turn to the hub.
When installed inside the cover, the inner drive piece looks like
The lip-looking things fit into the hub dial snugly to turn it. This piece is larger diameter than the hole in the wheel cover, so it rides on the inside of the cover, and the eight-point sticks through the hole and snaps into the outer disc.
Mounted together, the side view. I printed the outer disc in black to match the decal, but the inner piece was made with whatever I had a big roll of, which is a sort of odd tan-pink color.
The inner piece is printed in high density so the plastic is nice and strong; the outer disc is like a medium density as it's all that I think is needed. There is the possibility that the plastic will melt, but this particular plastic melts at over 200*C, at which point I think the wheel covers would be getting wobbly too.
I did make the pieces a bit thick for strength; here's the outer disc visible on the wheel cover. You can see it's a bit taller than the cover, but only by a millimeter or two. (Sorry, my CAD program speaks metric, so, err, "a fraction of an inch"
