There is a hole at the end of itJust drill a hole at the end of the crank, clean it up, weld that shiz...and send it
That’s should be May 2019 right there
The easy fix is to box it and run it.
You got everything at your place down here you need to fix it?
Take a pic from the other side when you get a chance. I’m sure we can come up with some ideas to hold you over for the summer.
mmm fun. The plate toward the cab (left in the photo) is that some sort of frame boxing that was done?
Yes, it was pretty much to raise the old shock mount up to the top part of the frame but is now in the way
I've got some of these, borrowed, that you can use. I have soldered before, and have the stuff if you'd rather go that route.Hey Jake do you have a good pair of wire crimpers or experience soldering wires?
