Not for a while nowShhhhhhh he's gona be a 5-0
Not for a while now
That's good. At least you don't have to start all over.Ya I'll be joining the next class and just working at the academy until they catch up to where I had to stop at.
Not a bad place. Optimally mount it somewhere others can see it and get to it as wellI was thinking between the shifters and the center console
Or peeI concur with that sentiment.. fire sucks and putting it out with half empty bottles of water or sand both suck..
Eeeeeewwwww... Mark... If it means anything to you I would pee on you if you were on fire.Or pee
My fire extinguisher is readily available, thank youEeeeeewwwww... Mark... If it means anything to you I would pee on you if you were on fire.
Just sayin...My fire extinguisher is readily available, thank you
I know I've had the fire extinguisher since December and it's just now getting put in the truck
It's like a winch... If your friend has one that's good enough!you crazy.
