75 Jimmy build FOOLSIZE (time to wheel)
Wheelbase: 108" Width F/R: 89.5" / 88" 3 link -upper: 32" -lowers: 32.5" -vert sep: 8.5" -panhard: 38" 4link -uppers:38.5" -lowers: 40" -vert sep: 9.5" Front DS 1410 HADCV ride: 33" Rear DS 1410 ride: 38"
I think more people would do it if the steering shaft werent right in the way. Not a huge issue but I know it is one of the factors keeping me from converting to a 3 link.
@brokenparts everything seemed to be in the way. But that was an issue. It's got a weird linkage set up now and most people don't stay with the mechanical steering and highsteer
Let me know if you want to hit up the Rubicon then. It'd be cool to wheel with you.
Scott
That'd be sweet. I'll most likely do a shake down run to the highlakes with @skunked once it's done. A Rubicon run would be sweet if the weather holds out
I hear you on that. I'm in the process of getting an '84 K5. I already have front and rear axles, an engine, transmission, and transfer case. I just need a few miscellaneous parts and once I get the Blazer, I'll work as quickly as I can to build it so I can possibly do a shakedown run with you.
Scott
