75 K-5 5.3 LS transplant [with pics]
buefchris
buena park ca.
I've been running this orignal untouched 1975 K-5's 350/350 through the Southern California desert for ten years. And with over 35 years and 205,000 miles It still ran well , but could use a rebuild.
The next engine needed to have fuel injection for inclines and declines [way too many scary times with the carbed engine].
I also wanted a 4 speed auto to replace the th350. The truck was taching too high on the highways which was killing the gas milage and the tired 350.
So, after priceing aftermarket injection systems a rebuilt longblock and a rebuilt 700r, It was cheaper to go with takeout 5.3 Ls and a 4l60e instead.
Nice swap, I'm tuned in for the outcome.
Apparently that makes two of us.
Anyway, along with the engine and trans comes everything else to make it run.....
Decided to go with the in-tank fuel pump which requires the late model tank with baffles.
I have the ECM and the factory harness,but knowing that the computer needs to have the securities taken out [and the harness looked like a nightmare] I opted for the custom harness. Both by Howell Injection.
There is no better time to replace the upper shackle bushings that when the engine is out too.
Now we begin the tear down
It will be easier to remove the front bumper and hood.
At hind sight, removing the engine cross member and the whole front clip[while being more work] would make for an easy install. I didn't do that:doah:
How come pulling a motor is easy and putting one in is a PITA?
This 350 will be going into a neighbor's "T"-Bucket project.
A lot better if you lower it down to belly hight.
One out and one to go.
Oh ya, forgot to mention when doing this conversion you'll need an aftermarket engine cross member of some brand.
The deeper it is the better.You could spend time modifying the factory one,but [in my opinion] why would you waste your time?
And with everything out of the way,one last shove and the 350/203 is down and out. It will be in the hands of it's new owner tomorrow.
A good thing to have these parts sold before they are out of the vehicle.
Since the engine compartment hasn't been painted in over 35 years, thought I'd better clean and paint it a little.
I took the battery out of this side to make room for the air box.
Don't know what kind yet. I looked at some of those UMP's and Donaldson's but most are huge to match the c.f.m. this motor needs.[And not cheap]
So, I 'll be looking at the junkyards for ideas.
This side is where most of my electrical will go with both batteries.
It needs a lot of clean up.
A buddy of mine made me a overflow tank for the radiator.[stainless]
It will mount back on the firewall.
Got the battery from RuffStuff. I could not build this box for what he charges for it.
Also, I had to change from the truck style exhaust manifolds to what is run in a Camero mainly because of the right hand side hitting the frame.Corvette mainfolds work even better but people want an arm and a leg for those.
Most folks notch the frame, :doah:I don't think so.
These were far cheaper than going with headers.
:DThat engine compartment sure came out nice.
Good job nice to see people taking the time to clean and paint stuff.:bow:
I wish they had that battery box when i did my tray that is a sweet set up.
Well, I mated the two together, looks like it's time to put it in
Installing the engine took more than one person. Thank goodness for bored neighbors.
Finally, it's in. Wasn't easy the ORD cross member had to come out in order to let the oil pan clear.
Even after it was in I still had to put spacers under the mounts not only to clear the cross member but, to make sure the exhaust manifold wouldn't hit the frame.
I've looked at other builds and they have the same clearance issues.
Maybe after I get it running I may have to change out the cross member cause it's too tight.
The power steering line was easy due to the help from a neighbor who had fittings custom made for his projects.
These can be tough to find.
Then I routed the return line to a cooler in the front and back to the pump.
The cooler is a Lockhart meant for a Harley Sportster I picked up at a swap meet.
Nice swap. Very nice. What. Kind of/paint did you use for the engine compartment? Did you just scuff the paint or did you sand it down? Looks clean!
I just sanded the big rust off with a wire brush,primed it and painted satin black by Krylon.
Any scraches I get just touch up.
