Also, the 241 has a place for the speed sensor and one for the 4wd indicator.
Does the 241 speed sensor have the correct pulse for the late model LS computer?Also, the 241 has a place for the speed sensor and one for the 4wd indicator.
Its gonna be a long slow process for me though.
Yea, tbi tank and sending unit with a Corvette pump
I welded the -6 bungs on the sending unit to make things easier to make fuel lines,, Do Not Do This!! What happens is the fuel gauge unit will fry and you'll end up buying another one.
The best way is to find the right fittings to switch it over.
Summit carries Earls fittings and is your best bet
Good thing I've read this, I was planning the same thing for my nephew's blazer. He needs to run a electric fuel pump for his late model BBC which does not have a boss for a mechanical fuel pump.Yea, tbi tank and sending unit with a Corvette pump.
Erl's part number for the conversion fittings from metric tbi sending unit to an.
9894DBJ ( 16mm line feed)
9894DBh (14mm line return)
Earl's fittings seem to be the only one who make them.
I got'em through Summit
