ricrok
Registered Member
ricrok submitted a new Build:
'75 K5 build AKA -10 Below Blazer
Read more about this build here...
I picked up my 75 a couple years back from my father in law for $2200. He found it in northern MN after it had just arrived from AZ where the PO had passed away. I've used it for tooling around the back 20 for a while and occasionally take it to a local mud hole. I decided that it's time to start tearing it apart and putting it back together because I wanted one since I was a kid. After having it for a few years there's a few things that I know I need to address. Body flex(already posted about rocker box design, that'll be this spring), seats and belts, axles, engine, t-case, and those crappy flares and hood scoop.
Here's the starting point the day I brought it home.
It's currently got a 327 w/ th-350 in it. I'm not sure of the t-case but I know it's not the factory 203 as it's goes from front to back 4L/N/2H/4H. I'd crawl under and take a look but my new polebarn doesn't have a floor poured yet and it's fricking cold here in MN. The 327 is a dog, it's way over carbed with a 750 Holley on it and you can tell it's tired from years of use. The carpet inside is some awesome redneck blue deck carpeting like you'd see on a pontoon. Observant eyes will spot the body lift which is also going the way of the dodo as well. All in all I have a lot of work in front of me but I absolutely love the thing and I'm looking forward to posting occasionally for advice, updates, and what not. I've been lurking for years before I decided to jump in so all the great rigs on here have helped to serve as inspiration.
All that said, here's project #1 since it's winter(hence the name "-10 below blazer" and I can work in my attached garage with some heat and relative comfort.
There sits the 14 bolt that's going in this spring. My 7yr old got an 18v drill for christmas and wanted to help me out. I put in a sanding disk for him and he's off to the races. Free rust removal service. I grew up working in the garage with my dad as he was a mechanic so I'm loving go out there with him and teaching him anything I can. I already have the passenger side hub/drum off to do the disc brake swap. My wife got me all the stuff for christmas for it. She's pretty understanding about the whole thing(she let me buy it on mothers day after all) and loves that my son and 5yr old daughter like helping. I picked up the 14 bolt and a matching dana 44 w/ 8 bolt hubs for $150 on CL. My son says...
,namely spending as much time as I could with him. This was a few weeks ago so I'm now back into life a bit. I had a spare set of Eagle Alloy 15x10" wheels that I was able to trade for a 700r4/NP208 combo and a pair of good front fenders. I still have to swap in a new front seal into the 14bolt and do a crush sleeve eliminator and that's back together and then I can paint it. The 4.10 gears will stay for now as they're in good shape so I'll spend my money on bigger needs at this point(rust). But I hope to get back into the swing here of normal life.
