CraigFulton
Help! This thing is running hot. Vapor locking and the floor is super hot to the touch.
I picked up this 76’ with a 400ci from a guy flipping it after original owner. He had the engine and trans rebuilt...among other things. It’s completely stock. He had a muffler shop put in a new dual exhaust, but nothing fancy. He put maybe 25 miles on it then I bought it.
I’ve replaced the radiator with 4-core aluminum, heavy duty water pump, 180 thermostat, new temp gauge, fan clutch, and wrapped the fuel lines all the way with heatshield product thermal line covers. STILL VAPOR LOCKS! Temp gauge shows right in the middle. I’ve noticed now that the floor gets so hot it will blister burn your fingers if you touch the seat mount bolts. Also, I’ve rebuilt the carb, added heat risers, and timed it to 6 BTC.
Anyone have advice to offer? I’m so confused on this one. I’ve been wrenching on these since I was born and I’ve never seen anything like it.
To cure the vapor lock I decided a couple days ago to buy the Holley Sniper Quadrajet EFI and upgrade to an ‘88 in-tank fuel pump with Holley 60psi pump. This still won’t cure the heat issues. Or will it? Any help please!?
