CraigFulton
I just recalled an epsisode of vapor lock my 76 k5 with the 400 had.
Could have happened to and sbc but i so happened to have that same k5.
It was outside Ely Nevada and 100 degree day.
Kept stalling on those passes.
For whatever reason, I pulled the gas cap and a blast of pressurised vapor came out.
My vent line thru thr canister was plugged by prev. Owner.
Fixed it.
Still had issues.
Replaced fuel pump.
Still had issues.
Tightened top of carb.
Problem solved.
But any one of those things could have been the issue.
The plugged fuel tank vent was bad but wasn't the cause of the stall.
Sometimes it just takes a steadfast approach of following each problem and correcting them.
I would start by actually verifying the coolant is getting too hot.
Use a seperate thermometer.
If it is, check that the thermostat is opening, or not in backwards.
If the coolant is only reaching 180 at the top hose and perhaps 150 at the bottom hose, you don't have an engine over heat problem.
I thought same thoughts. The gas cap is good. New tank and sending unit. Vent tube is good. Yesterday I noticed carb bolts were loose. I tightened them but not much. Today it almost vapor locked.
Still. Should there be that much heat on the trans and floor?
Lines at the trans
