N
The head gaskets should have the holes in them.
That is probably not the problem.
But if he put a different set of heads on.. like 350 heads, they would need to be drilled for the steam holes to match the 400 block.
Call and ask him about steam holes.
What is the coolant mixture? @K5wrench asked that a few posts back, and maybe I missed your answer. If this thing is running straight water, we have an issueI will add that the temp gauge gets to half pretty quick. My other cars it takes 4 times as long but they are modern.
Coolant is almost 50/50. Definitely more the green stuff than water.What is the coolant mixture? @K5wrench asked that a few posts back, and maybe I missed your answer. If this thing is running straight water, we have an issue
Also, how close is the new exhaust to the fuel lines? They may have created a problem there
So the engine has not boiled over?
Just the floor gets hot?
If that is true; check for an exhaust leak, or maybe just pipe run too close to floor.
You mentioned the "tube" in quadrajet missing.
Those main jet air bleeds fall out all the time.
Can also cause poor driveability that seems like vapor lock.
Check that you have the right gasket at top of quadrajet.
There were some that look alike except the main jet air bleed area of gasket is square or round.
Mixing them will cause big lean running issues.
Also, loose carb top screws or broken gasket can cause vapor lock type symptoms.
Usually runs okay at idle but stumbles when secondarys open.
Confusing the issue with a broken or misadjusted secondary air valve spring.
Block is never overheating. I think the fuel is getting hot from exhaust/transmission before it gets to the pumpI would guess that the head gaskets possibly are not opened for the stream holes. But again at least one head needs to come off to check
If it runs well wouldn’t think retarded timing is the cause.
Definitely don’t keep overheating a 400 block.
Vapor lock is a common problem with today’s fuel. Overheating only exasperates the problem obviously.
I had to run a return from just before the carb back to the tank to help the vapor lock issue although my 74 350 although it never quit and shut off completely.
