My goal of having it running today was reached.
Started the morning by getting the driveshafts figured out. From my stash out in the shed I was able to get something together for the rear. Had to mix and match some u-joints/caps but I got it done. The front turned out to be long enough, just barely though. Before I go out wheeling I'll cut and lengthen it.
Since I didn't get any battery cables I made my own. I've already got the crimper, ends and shrink tube just had to buy some cable. Made one positive and 3 negatives (battery to motor, motor to frame, frame to body).
I bought a couple gallons of gear oil because when moving the trans/t-case nothing came out the several times it was tipped over. Pulled the drain plugs and much to my surprise it had fresh oil in both. So I just topped them off. I'll use the rest for the axles (no clue what this thing has for gears or if they match).
Stuck some new plugs in, along with the wires that were on the motor while it was in the van (just had a tune up before my uncle passed away). The carburetor I used needs a rebuild badly. It came off one of my Camaros about 5 years ago. It's been sitting on a shelf in the garage since I took it off. In that time I've painted about 7 cars and gone through countless grinding wheels/cut off discs. To say it had a layer of dust on it would be an understatement. Did a quicky clean on it and hoped for the best. I'm pretty sure I took it off the Camaro years back because the accelerator pump was on it's way out...it didn't get any better. I'll look for a rebuild kit for it tomarow. To get me by until I can get a better one, I installed a cheap electric fuel pump back by the tank (block has the boss but no hole drilled for the pushrod).
Hooked a battery up, powered up the fuel pump to check for leaks (none), crossed my fingers and turned the key. Motor rolled over a few times then fired right up. Seemed to run smooth (despite the junk carb), just wouldn't accept much throttle (or quick changes) without dieing. Didn't check the timing with a light, but from the way it started I couldn't have gotten it too far off. I found the factory gauge wiring tucked up out of the way. Took a gamble and hooked them up instead of the Sunpro gauges the PO had under the dash (I hate them down there). The volt meter started working but neither the water temp or oil pressure work. I'll probably put the aftermarket ones in the stock cluster like I did in the 86 K10 that I had. I did find out what the switches do, one is for the heater blower the other for the electric fan. The push button is for a washer pump that has nozzeles in the grill, I don't know WTF that is about.
Reattached the core support and got everything aligned (except for the hood). I'm not 100% positive but I think the headlight trim is from a 79/80 truck. I used a set of clear lenses for the front parking lights (what I had in the shed, didn't get any with the truck). Going to try to find some amber ones, I think they'd look better with the white. And on that subject, I think at one point the truck was painted with appliance paint, at least the lower valance panel was. It has a striking resemblance to the finish on my early 90's Magic Chef stove and my late 80's Amana refrigerator. When checking the lights I broke the turn signal switch.
Still have a lot of loose ends to tie up. Need to run the wiring for the fuel pump (just have a temporary wire ran), dig through my pile of radiator hoses to find some that fit, take the single electric fan off and install my dual windstar fans, exhaust (plan to use the pipes/mufflers from my 85 K20) bolt the floor hump back down, shifter boots, bend the trans shifter more towards the drivers seat, fix the turn signal switch, neither power window works, align hood, fix the wiring under the dash/add relays for the fans and lights, get some kind of trailer hitch on the back (have one that may work), maybe throw the factory tow hooks I saved from my 77 K20 on the front and probably a few other things I'm forgetting.
It was a rain/snow mix most of the day so I didn't get the camera out, and my phone doesn't like to take pictures when it's cold out. I did get a few just before I called it a night though. Have to wait for another day for more.
