I'll send you a picture when I get home. I'm pretty sure the area in that picture that shows rust through is solid on my K5. I have a little bit of rust on the front of it near where the brake booster goes which is common on all square bodies.
Thanks, they make patch panels for the bottom half, but not for the top. I'd be interested if yours looks solid or at least better than mine cause it will save me some fabricationI'll send you a picture when I get home. I'm pretty sure the area in that picture that shows rust through is solid on my K5. I have a little bit of rust on the front of it near where the brake booster goes which is common on all square bodies.
It's a 2wd transmission 4L85e, I'll fit it to my NP205Is the tail housing not needed for 4wd?
Can you do me a favor and take a photo (several please) of the body mount under your back seats?? Wide angle and close up. I need to see the bracket and where it is positioned...
