Something like this. They make a double line clampYou got a picture of what your talking about here?
https://www.discounthydraulichose.c... BE-5125 - Support Clamp, OD = 1.250" - $3.68
Work fine if you stud the lower and use lock nuts on the top
Got it. Not quite what I had in mind. I was thinking more of a strap and bolt setup. I think those would be fine with a nylock nut on them.Something like this. They make a double line clamp
https://www.discounthydraulichose.com/BE-5125.html?msclkid=2719d18b90331b16897b8caef187d9ef&utm_source=bing&utm_medium=cpc&utm_campaign=**LP - Shop - Other Products&utm_term=4582420869790508&utm_content=BE-5125 - BE-5125 - Support Clamp, OD = 1.250" - $3.68
Or a better bumpstop to limit what up he has to avoid killing the shocks.Yep you need more up...
Makes sense. I was thinking that using a tall urethane bumpstop ( like on the rear of a 2nd gen S10 Blazer) bolted to the frame directly over the spring plate might limit travel enough. But if the body of the shock is longer it would bottom out before the bump was compressed at all.If he stuffs the axle, it will still bottom the shock because the shock will travel up faster than the point of the axle that hits the stop
This is where the cycle routine comes in handy
Those work pretty good but I've had some trouble with them popping out of the metal cup.Makes sense. I was thinking that using a tall urethane bumpstop ( like on the rear of a 2nd gen S10 Blazer) bolted to the frame directly over the spring plate might limit travel enough. But if the body of the shock is longer it would bottom out before the bump was compressed at all.
So where are ya going tomorrow?New shoes and new steins. The Dodge shock mounts did not want to play well with the stock upper mounts so off they came and I welded new ones on.
I really did not figure I would be able to feel a differance but there was a noticeable differance from off the shelf shocks.
Highway manners were a bit different with the new tires and power wise I am impressed how hard this thing pulls in 3rd and even 4th gear.
Plans are to go wheeling tomorrow however I still had not tried the four wheel drive so an asphalt pile at work did the trick. 1st gear and 4 low (wow that's low) and it crawled right up.
Thanks Rob, after I get my A/C lines installed I will make hopefully the last bracket that will support the wire loom going to the computer and everything will be tied up/together and have a bit more of a finished look. The devil is in the details and I could not have pulled this off without help from you, Larry and all the gang from CK5. You guys set the bar pretty high and I just hope my hunk- o- junk can get the job done.I really like how the L29 looks in the engine bay. Good luck with the test run! Take pics!
I would like to invite the gang from CK5 but the truth is except for the general area I have no clue where the actual trail is!So where are ya going tomorrow?
That’s ok, we shall wheel with you soon!I would like to invite the gang from CK5 but the truth is except for the general area I have no clue where the actual trail is!
