78 Blazer Buildup by Shaffers Offroad
sincity78
Registered Member
Reno, NV
The plans are:
3 link front suspension w/ panhard, 14" fox coilovers, 4" fox bumps
4 link rear suspension 16" fox coilovers, 4" fox bumps
2" solid 7075T6 lower links with 1.25" hiems
1.75" solid 7075T6 upper links with 7/8" hiems
42" Pitbull Rockers on 17" Walker Evans Aluminum beadlocks
Dana 60 front, ARB air locker, 4340 Axle Kit w/Super Joints, 5.13 gears
Ballistic Fab double shear high steer arms
PSC Hydro Assist high stear
1.75" solid 7075T6 Tie Rod/ Drag LinkReid Racing steering knuckles
Dana 70HD rear w/detroit locker, 5.13 gears
Atlas 4 speed transfercase, max 5.4:1
SS Mega Monster TH350 Transmission
Punisher Pro-Street 2300-2500 Stall Torque Converter
Flat belly crossmember, 24" belly height
Carbon dash with Autometer Phantom II gauges
The wheelbase is going to be stretched from 106" to about 116", 4" front, 6" rear. The front and rear of the truck will also be narrowed ~22-24" aka dovetail. Quarter panels from a truck will be bobbed so the rear wheel openings will be moved back appropriately.
Here are some starting pictures:
almost perfect entrance angle
rear will be further back than this
rear suspension gutted, gas tank removed
front coilovers
4 speed atlas, monster transmission th350
flat belly
gas tank moved up to clear rear axle at full stuff
body clearanced for atlas
yummy flat goodness
front suspension
What is the limit to wheel travel with your front suspension? Is is shocks or driveshaft u-joint binding? Have you run this combo before? Is this similar to the offerings from Off Road Design? Cool build
That's pretty good progress for your first day....
Done by tomorrow then? :thinking:
:D
:usaflag:
Should be the limit straps.. :)
drive shafts aren't in place but we will be running a cv front shaft so I don't think it will be an issue. Everything is custom, first time out. I'm pretty sure this is the first blazer they've done. Parts were designed in solid works and cut on a torchmate cnc plasma table.
I wish LOL. These pics go back to early this year. Just wanted to get some decent progress before starting this thread.
I'm not a fan of mini monster trucks, but this blazer is bad ass.
Needs a monster motor though.
