78 K5 Linked/42s Family Crawler
Poor man budget build trying to make a dependable and capable trail rig for the family to enjoy.
Was just gonna ask if the tires hit a full lock, but it looks like you have the links in far enough.
Not much of an update, been waiting on parts to come in the mail and old furnace can't quite keep garage warm in these temps lately.
Been mocking up shocks and had to cut rear frame to clear shocks at droop. Not the prettiest setup but it'll work for now. Hopefully this weekend it'll be sitting on its. Also bolted up the hydroboost brakes and cut up the tube cowl hood that the previous owner built. Hurt me a little to cut up the cowl but it just wasn't fitting with the rest of the setup. Decided I'm going with flat hood.0131181819.jpg 0131181817.jpg 0204181707.jpg 0204181707a.jpg 0204182032.jpg 0204182033.jpg 0206182328.jpg 0206182331.jpg 0208182308.jpg 0208182307.jpg
I plan on running full doors and body skins and hood. Unsure if wanna try to keep shock hoops under the hood or bump them up thru with longer tabs on axle. What do you guys think?
And the small hoops the rear shocks are attached to are just temporary for mock up. Gonna build a much better, stronger mount.
What's the clr of the die for the shock hoops?
Not sure. I bought these hoops from liquid iron industries. I can get ya some measurements tonight if ya want.
I haven't bought a good bender yet. I just tweak some tubes with a harbor freight pipe bender.
I have 2 sets of these same hoops I'm probably not using but they are 1.5" tube instead of 1.75"
I have a hydraulic hossfeld and I'm going to make my own soon so I was wondering. Most of my dies are way tighter than that. Thanks for getting back.
Supported the front shock hoops. Tried to follow the lines of the cage a little for what its worth. They feel solid now, I was surprised how much twist the frame has before the supports were in.
Not much done but every little bit counts. Only get a few hours a night if I'm lucky, 8-12ish then up for work at 6. Fun fun. Still more in thinking stage than doing lol.
