Haven't had a nice day lately to clear coat the wheels ,but I did pick up the tires. Brake brackets are still a couple weeks out so I'm focusing on the front of the truck as I can't do much until they arrive..
I got the fenders on, one inner installed, replacement should be here in a couple weeks as well. Aux battery tray mounted, started labeling wires at the bulkhead. And seeing how it all lines up, being on the drivers side. The terminator should be here by the weekend, and next week I'll get around to messing with it. Hoping to fire it up sooner than later, won't be mobile but an open header fire up is almost mandatory, I'd think.. I don't have any money for a dash yet. But I'll use the handheld screen for temp and oil pressure. Also hoping I can use it to monitor oil pressure with the engine off, as I prime the engine first. I was going to use my mechanical gauge but I can't find the metric thread, to 1/4 npt adapter I had laying around...
I'm going to re use the th350 dip stick for the 4l60e. The tab on the original tube was short so cut one off a broken tube I had laying around and got it to work, got some silicone heater hose, so now I can fill the system. I stupidly ordered a stock GMC fan set up because they were on wholesaler clear out ( rock auto ). After thinking about it I figured I should check the length. Turns out the dual fan is going to be way too big so I ordered up a single fan. That's only 16 inches in diameter. I knew guys used Ford Windstar fans... Didn't realize it was a size, and not cost issue..
just another tuition payment is all.
Once the new prop valve arrives I'll be able to hook up to the master and finish that all up and snug down the front end a bit more.
There is so many little things to do.. and I can be a real scatter brain someti...often haha. But it feels good to be getting them done with.
Still need to figure out a the power steering and also connecting to the fuel tank. The fuel rail, to 6 AN fittings I have don't fit, because the piece of fuel line ( hardline at the sender ) is about half inch too long from the raised section,to the end. Causing the adapter to not be threaded on. Can I just cut these to length or will I mess up the sending unit at all? Intuition tells me it'd be fine, but I can't keep buying some things twice haha.
Is it possible to flare stainless steel with a regular flare tool, or will I just mess up my lines like some people say?
