79' GMC C15 - Spruce Caboose
79 GMC 1500
I got the new pump, turns out the play in the pulley shaft is normal but this one doesnt make that strange noise. Cleaned up the alt/ps bracket since it was off and with a new ALT and PS punmp, i hope to never have it off until the nukes itself. Got the old pulley off and the new one on.
PXL_20210416_180937675.jpgPXL_20210416_180941513.jpgPXL_20210416_201024356.jpgPXL_20210416_201052774.MP.jpg
The brake brackets showed up, im still missing a rotor thats lots in amazonland somewhere but i got to mock it all up on the one side for now atleast. happy with the brackets, they are beef! its nice that they will fit the stock or wilwood 4 piston disk brakes.. gotta be going pretty fast to justify those on the rear but one day..
I ordered a set of 275/55/17s and they will be here in about 3 weeks, after that all i need is a driveshaft and she should move around. Time to see if the trans is good or not!
I got the new alternator on and wired in. I ran a single +12v switched power source inline with a 470 ohm 1/2 watt resistor. I folded back the end of the resistor on both ends to double up the thickness before crimping it into place. It also made it so i could get a bit of an overlap on both heat shrink crimps to protect the resistor. Its now outputting about 14-14.2v at idle. Which still a bit low i think.. so im going to look into the single wire process more. I may need more resistance to get a proper voltage out of it or i have a shitty ground somewhere. There is also zero room for this plug to be put in or taking out without the alternator coming off, so i think im going to flap disk the corner off for ease of life.
Now that i have the brake brackets here and installed i could go ahead and mount the calipers and see how i can make the stock oe front brake lines work on the rear axle since i have them laying around and im using oe calipers. I got some weld on brake tabs, but i still need some nuts to fasten them down but for mock up its great. I figured id buy a chunk of 3/16ths brake line and bend these up and figure it all out before i think of cutting flaring my steel lines. Im not sure the titan flaring tool i have will do stainless well, so i may just take the mock up line and have custom ones made, they are going to be about a foot in length so they shouldnt be too much. It worked out really well, the stock oe brake lines have this locking tab on them which attaches to the upper control arm, and it lands perfectly inbetween the u bolts so i tacked it on good.
Ive been diving into the rabbit hole of tuning software. Although the holley computer has a laerning feature, the more i do research its best at some point to turn it off and have a stable tune running. This means understanding volumetric efficiency charts and how that all ties into the target AFR tables. I cant do much fine idle tuning until i have a good stable tune and my fuel numbers figured out but it seems to be running good except for the fact the thermostat doesnt seem to be opening so it ends up running at about 215-220F, and i dont run it for longer than i have too to troubleshoot the coolant issue. Took the factory one out and heated it up. it eventually opened but made a noticeable noise breaking free as it opened. The water pump isnt weeping and even if it was bad since the thermostat is lower on the LS i would imagine gravity would feed enough coolant through for the bottom rad hose to get hot.. so I orded up a new thermostat because im hoping its the issue, plus heating them up can warp the springs and im never that patient.. :whistle: Atleast the gassing of header paint is over now..
On the gen 3 LS engines they had 4 steam ports due to the thermostat being lower in the coolant circuit, and on gen4 Ls engines they only have two at the front. The idea of elimnating the two at the rear was that due to the angle of the engine the highest point is still at the front. Any air built up into the system is supposed to be bled through the steam ports. I just drilled a hole in the block off rubber cap i have on the rad and slid it in with some high temp sealant even though its a SNUG fit and im hoping it holds.. if it doesnt ill have to figure something else out.
View attachment PXL_20210418_181916547.mp4
I got the rest of the exhaust hung up. I had a 45 degree bend i cut out of my buddies old exhaust and the left over eyeballed 45 degree off cut bend from the head pipe/y pipe merger. I had to step up the exhaust to get it over the rear axle, and i have no idea how this truck will sit so i put the exhaust around in line with the factory bump stops for height, and ill drop it down once i see where everything sits.
PXL_20210419_212128889.jpgPXL_20210419_214242083.MP.jpgPXL_20210419_215120412.jpgPXL_20210419_215128311.MP.jpg
Got the rest of the brake lines plumbed, and made a bracket for the rear brake union to sit on. I tapped it for a M10 thread and used a bolt i had. I need to find some nuts to fasten the flex lines to the tabs but thats about it for now, until i get a new disk disk prop valve and i can bleed the system...
Do disk/disk prop valves still distribute 70% front and 30% rear, but use a different amount of force to the rear? Im wondering what the consequences of running the current one..
This handheld titan brake flaring tool is so nice that its portable. Can be clamped onto an existing line easily and works very well. The one side didnt really turn out as clean as i wanted it too, but its functional so im more than fine with that.
This rotten bedside has been staring at me for long enough, and schools starting up in a week. I guess my first semester is going to be all online which im really not a fan of at all.. but one good thing is for the days where i have a 2-3 hour break inbetween classes, ill be home so i can sneak into the shop. I havent dug into the other side, but i know the top of the wheel arch isnt nearly as rotten so im hoping i can get away with the two bottom patches only. It is a huge patch but its sorta nice in that way too. I have no real idea what im doing but im finally at the point where i feel a little confident in my skill, so things are more fun and less terrifying haha.
Got it pretty mocked up for now but im gonna fiddle with it more before i start cutting it.. Like any repo panel, they only fit so good. Im happy with trimming up the edges if everything else is nice and sturdy and these definitely are. I wasnt really sure how these are meant to be installed. I figured id cut the old one out. Mount the new one the way it seems like it wants to go. Ill clean up the gap and weld it/seam sealer on both sides, and I plan to rubberize the wheel tubs as the are solid.
PXL_20210421_175304933.MP.jpgPXL_20210421_180426253.MP.jpgPXL_20210421_221615916.jpgPXL_20210421_221620257.jpgPXL_20210421_221631614.jpgPXL_20210421_221655632.jpgPXL_20210421_221752862.jpgPXL_20210421_222011231.MP.jpg
Thats the nicest way ive ever been called a loner haha. The shop really is my happy place.. everything ive battled with my whole life, goes away when im in there. This hobby is a love for squarebodies and chevys, but its also so much more than that. Its therapy to me.
....plus im unemployed and its 20 degrees and sunny again :whistle:
oh and the voltage drop was a loose ground. A single 470 ohm 1/2 watt resistor inline with a +12v switched source to the ALT will get the single wire alternator to run at 14.55V with no ECU input. I know people have just put an idiot light or something inline to act as a resistor but i thought this way would be easier and less to worry about later on.
Threw some more hours at the bedside today. It was a real pain the ass to get in there. My two big fab magnets and 4 little ones werent really up to the task of holding the panel in place for the final fitting and tacking. I dont think ive sworn that much in a long time haha, i didnt expect it to be much different though... Usually is the first time ya do something. In the end i think it turned out good enough. i lined up the top and both corners and tacked it in place with the pannel proud of the inner fender lip, and then slowly tacked it and moving the panel into place as i went down. I then put a few self tappers on the inner lip where the two panels meet to hold it in place as i made way further. It was fun, annoying, did some good welds, and burned some holes. I did end up with a bit of a gap for a few inches on the right hand side which will take me a bit longer to fill in without warping the panel. I put a 12 inch straight edge across it and it doesnt seem to be horribly warped anywhere. Theres definitely spots where its 1/6-1/8 but overall it doesnt look bad.
PXL_20210422_182944021.MP.jpgPXL_20210422_174117756.jpgPXL_20210422_174110280.jpgPXL_20210422_185059241.jpg
PXL_20210422_203515887.jpgPXL_20210422_214424891.jpgPXL_20210422_214802283.jpgPXL_20210422_222403939.jpg
This replacemtn panel has a different style and flare to the bottom of the frontside wheel arch, on the oe side the 90 degree lip on the bottom flattens out and the brace is mounted there. Didnt realize it until after. Might try and take a stab at cutting and hammering it to match? I do have two new support rods so ill see how it fits in there n decide.
I checked the other side and as happy as i am i dont have to do the top itd be nice to apply all the things id change if i was to do it again. The inner fender on the other side isnt rotten out either, so ill get away with just doing the two bottom patches for now.
Maybe im just not old enough, but i dont think iver seen a drywall mount used in an autmotive situation before....
Lmao! Those drywall mounts hold!
Never seen that before either... but I have used liquid nails for seam sealer successfully. Actually works great!
Your panel looks real good! Nice work!
You need to find a few of these. It's a magnetic flag mount for guys hauling oversize equipment. Super strong. You can put a long bolt in it for a handle to make removal easier. They would hold panels really well.
No shit, holding solid some 25 years later from saskatchewan to here haha. Im the third owner so it was either my buddy or his grandpa. i doubt my buddy would even go that far to have fixed it haha.
Thanks it was a good time!
Ahh i know the magnet the minute i saw it! As a Mobile crane operator and a guy whos heavy hauled before, they sure would work! Thanks for the idea.
Figured after a a few warm ups and idle runs with some throttle here and there is change the oil to get all the assembly lube out. Is this what the oil normally looks like mixed with a bunch of moly graphite assembly lube or is this tub staring into the dark hells of the engine eating itself lol?
The ls engine book I followed said you don't have to use that lubricant anymore since there's no " break in " period with a truck ls cam. But at that point I had already lubed it up with the full package as directed by the manufacturer of the cam
That looks bad, but at this point I wouldn't assume the worst until you run it more with new oil. It may be cleaning out.
  • Like
Reactions: bix
I’d think if that was metal and not moly, it would sound like it’s coming apart
Thats sorta what i was thinking but i havent owned enough motors to trash one yet, so not too sure. The motor came out of nanaimo fire department truck that was hit bad on the rear passenger door, had good compression before i pulled it but never checked after installation because i didnt touch the bottom end. Put a new filter on and I took both valve covers off. Didnt notice anything that was alarming or looked out of order, totated the engine over by hand and checked springs, rockers and pushrods at different strokes and it seems all normal. Filled it with a fresh 6L of 5w30 Non synthetic. Fired it up and went through some rpm and let it idle. Didnt notice any peticularly worrysome noises. Did notice a bit of noise coming from somewhere around cyl8 but hard to tell. Id have to dig out the stethescope to pinpoint it but it doesnt sound bad enough to create that much metal. I plan do to some more basic tuning with the new oil. And then ill change again to try and hope it looks better than stargate galactica in the pan.
Idleing at 31 psi oil pressure after change.
PXL_20210426_230712354.jpgPXL_20210426_225042029.MP.jpgPXL_20210426_225036397.jpgPXL_20210426_224913847.jpgPXL_20210426_230707413.jpg
Hoping i didnt put these stickers i got frome ck5, up too early :haha::weapon23:
Well if it’s wounded, run it. When it flies apart, you’ll know what broke
:waytogo:
That's not too different than what the oil looked like coming out of my crew cab after the distributer gear pin sheared. Everyone talked me off the ledge on that one and so far it seems fine. My problem is normally don't look closely at the oil coming out so I don't really have a good measure of "normal".
  • Like
Reactions: bix
