Its been awhile but to make a long story short.. parenthood is craziness, everythings super expensive, never thought id go to the artic circle for work or above Alaska in the Yukon... but that was neat, and I also got canned at my more recent " long term job " the other day after reporting unsafe work because my supervisor couldnt manage his way out of a wet paper bag.. So im currently stay at home daddy daycare at the moment, which is great for all reasons except financial ones, but one of those reasons being I can work on the truck again. Pulled the truck out of the old towel smelling car tent and got it in the shop.
A quick take on what life it has had since putting the engine and transmission back together.
Engine did not run correctly after getting the timing components installed and the transmission mated to the engine and stabbed in the truck. After cranking and cranking with some random firing.. i realized i was washing the cylinder walls with fuel and decided to use the computer for its best features. In the holley software I turned on diagnostic 6 and 7 and then data logged it while trying to start. Turns out the crank signal was junk.. installed a new crank sensor and crossed my fingers. It starts up but doesnt idle properly and has strange loops and humps to it. I confirm a bunch of things are at proper spec but still the AFR is all over while running.... after quite some time it dawned on me that maybe the throttle body i put on was the wrong one.. Turns out it was, i had one laying around the shop for my old gmc work truck which was a 6 cylinder and thats the one that ended up on the truck by mistake. Although they look identical, i was wondering if the stepper motor and holley ecu were off beat somehow.
Cold starts are good, idle is decent with changes to the map showing corresponding changes in throttle response and AFR at idle.. things are good..
Until I shift the transmission into D... no clunk and no foreward movement at all. At first i was almost convinced i pushed the truck around the yard with my van and had left it in drive and not neutral... ( Rushing and not removing the driveshaft is a bad time ).. While looking online, the symptoms i have seem to line up with a broken input sprag.. which would probably want to implode if the truck was pushed in reverse while in gear ( seemed to make sense..? ) So after the truck didnt run and the trans didnt move it, back in the tent trailer it went until recently....
Symptoms and clues :
-No movement in D
-Metal or clutch material in pan ( Z pak clutches, and kolene steels are dark so its hard to differentiate )
-Movement in 2nd gear manually but shaky and bad ( I read that its using the piston mainly to seat these clutches so driving this way should be avoided as to not damage the apply piston ) so very little moving was done in this state. This was also a symptom tied into having a junk input sprag.
-Reverse seemed to work but didnt have much room to test it out, i remember it clunking in gear properly.
Ive decided to sell my dad wagon ( or ls swap it into a rear wheel drive drift car ).... either or i need the truck to be a daily again. Got the truck in the shop and dropped the pan.. Fluid is still obviously new and red but has either clutch material or some fine metal in it. Out she comes!!!
Once i got the trans out and up on a workbench the disassembly started...
I knew the input sprag was only about halfway into the case and just kept thinking I would find a smoking gun somewhere... I did notice some wear on the copper/brass input sprag race, and i had already ordered a 29 element double cage borg worner unit so that will get installed on re-assembly.
