Tinkered some today, got new ps pump belt on, new ground cable on, and got the rack off. I also tested the temp gauge and it worked, so I got a new temp sensor on to now see If the thermostat is closing properly, as the heat sucks in the cab. Also cleaned enough to get the suffix code, 350 , 175 hp. When I looked up the suffix codes some motors had differences in hp of 15 or such but same ci.. what would cause such factory differences?
