Pull that tank out of the box and make sure the filler neck seam isn’t cracked where it meets the tank. Common issue with the $hitty packaging.
Thank for the heads up! I inspected and sprayed brake clean all around the area, and watched inside the tank. If it's cracked brake clean will flow right through, I saw no leaks or cracks.
The box was hammered to shit also. I would not have thought of that though.
