79 Pickup build-Update 11/22 w/ lots of pics
Ok so really the only things i have questions on are the gray wire in the second pic, just a single spade female connector, and the second half of the coil. I cant see any wires missing on the harness itself... Isnt that second connector part of the main harness? Also, where do those wires go to, if i had to splice it in?
Well more questions now:doah::haha: Few more connectors, a few in the cab, one in the engine bay. I don't think they are anything important. I did cut a bit of the harness out that went to things I knew I wasn't going to use, so I don't remember if these are needed or not:crazy:
This connector has a single tan/ white wire
This wire is cut and is all tan (it leads to that connector in the back of the photo)
This connector has an orange and a black wire going to it, Black is striped with white, and the orange with a black stripe.
This connector has a pink and a purple wire going to it
This connector doesnt really look factory, has a single blue wire going to it
Heres the one in the engine bay, single round connector
wow someone needs to lable more next time.
last pic might be the o2 sensor wire. is it a purple if so its o2.
Label, no way, I have mind like a steel trap!:crazy: O2 sensor wire is right:D I still cant for the life of me figure out WHERE THE HELL the other connector for the coil went:confused: What does it get wired to?
the tan/white wire is connected to your ebrake idiot light.
So I got ALOT of work done this weekend. Axles are in, springs are in (these are temp springs, until I finalize the suspension. Tranny and t case are in. The rear driveline is measured up. Hydro clutch is installed.
So what I have left to get it running:
Wiring:
Brake lights
Head lights
Few misc on motor
Fuel System
Finish running gas lines
Mount tank from K5
Exhaust
Shorty headers
fix y pipe
Misc
Finsh up the cooling system (Overflow tank/ hoses)
Plugs/wires, cap/ rotor
Rear driveshaft needs to be lengthened.
Brake line connected/ bleed
Rear shocks
vacum canister/ lines
Cause I know yall need pics:D
So I came across some money...Time to do what I always wanted... BUILD IT HOW I WANT IT:D So im going to have an updated list of what im planning to do with her. Im gonna start the ordering process quite soon once i research all the cost and try to find some used stuff.
Right now, its tbi 350, sm465, 10 bolt/ 14 bolted detroited. 4" bds all spring lift, 35" Mickeys... NO interior haha
So heres the plan:
Suspension/ Steering
Front:
52" tuff country rear springs
DIY4X front shackle hanger
F250 towers
Bilstein 5150's
Rear:
3" tuff country 64" springs
4" ORD shackle flip
Bilstein 5150's
Home built inboarding
Steering:
Ord crossover (not highsteer)
Ord heavy duty tierod
Weld and bolt in steering braces
Drivetrain:
5.3L GEN III :D
Hydro sm465
NP208
Locked /disced 14 bolt/ d60, 4:10's/ maybe 4.56
Body/Interior
Going for a clean body. Nothing fancy. 84 nose.
Im gonna be build a custom dash, buckets, console and diamond plate trim panels
Pics will follow:D
so far, thats looking very very familiar. I just wish my 79 was that strait and solid... who am i kidding it would get all smashed up in the woods anyways. I love having a POS sometimes:D
Ordered the springs, some susp mounts, disc brake mounts, diff covers. Goin to pick up the motor this weekend hopefully. Maybe a d60 too :D Gotta get on ordering more...:crazy:
So what exactly are you using off of the blazer I sold you ? I see you put the tires and rims from the scrappymoble onto your truck. Did you say you were going to put the front clip and bumper onto the truck ?
what are your plans with it ?
yup front end and bumper, still got her sitting complete out back.
Mike, gonna try... thats if its done. well see though:crazy:
Just picked up a 60 last night, along with a 2wd steering box, and a few other odds and ends.
Got some updates for you boys. 4 working days into the build
Truck is down to the frame, 3/4 of the way coated. Im using herculiner after I strip it to bare metal.
Wiring harness for the motor is just about complete.
14 bolt is ready for discs, Ill have it completely together tomorrow.
All the parts are coming in. Its like santa comes daily:D
Here's some pics. Reassembly will commence tomorrow. Hoping to have it back on its feet, cab on, and start wiring by this weekend.
And yes, I know one of the disk brackets is oriented wrong:doah:
cool stuff, man you ain't wasting no time are ya. How's the weather.
kudos to you for working on it outside.
