Paying attention to this one.
Only thing I have to find is a D60 out of a 78 or 79 Ford (The purists are screaming), I know "good luck".
not to awful hard to find out here
. I have only had three of themnot to awful hard to find out here
check KSL.com classified there are usually a couple on ever once and a while
one a bit old
http://www.ksl.com/index.php?nid=218&ad=9142645&cat=103&lpid=7
didn't say if it was HP or not though at that price it better be
Well. if he is going to stick with the NV263Can you move the cross member above the frame lip and shorten the cross member support on the right to compensate? You will raise your tranny and gain some ground clearance.
I think he can use a 2wd crossmember with a shorter poly mount.Can you move the cross member above the frame lip and shorten the cross member support on the right to compensate? You will raise your tranny and gain some ground clearance.
Cool, I was wondering when you were going to start a build thread. So being from Fresno are you a Pismo guy or do you head to the hills and play in the rocks?![]()
