I read through your thread today, huge waste of time. There were maybe 5 vehicle related posts in the 180+ pages.
Good thing I did it at work, that way I got paid. I do like your winch mount. I was wondering if I could fit one back there and you managed to take all of the guess work out of it for me. So I will be stealing it. I happen to have a good size chunk of 3/8th plate sitting in the garage, that otta work. oh and the front recovery points...I'm taking those too. I do have a question however. How did you mount the flat winch plate to the curved frame? Just bolt it down and let there be gaps, or make standoffs to level it out? The picture in your build doesn't really show.
Speaking of a winch and your mounting. I bought a Smittybuilt X20-12K today. Should have it Friday.
Yep, I'm in Roy. So not too far from you if your thing is correct.
I'm taking a modern, high revving engine that makes just shy of 400HP and mating it to an antique chunk of cast iron that was probably formed by the impact of the asteroid that killed the dinosaurs. In its prime it probably had 150 hp feeding it. It is heavy, clunky, and has tons of rotating mass whirring around inside it. I can foresee many times Ill ride the revs out and try to shift just to have it not go into gear until the revs come down and the trans is happy. On the other hand, I don't see it breaking.
I had all of this junk waiting on the porch for me after work today.
