I spent 3 hours or so this morning working with the body alignment. Measuring everything I can measure.
Cab to frame, fenders to frame, used a straight edge from the doors on the body line extending out to the front of the fenders and those are off by 1/16" so, I'm thinking the body is mounted as straight as I can get it.
No matter what I do the hood is way out of whack. Needs to come forward on the drivers side front and back on the passenger side front but at the same time, the front of the hood needs to go toward the drivers side.
I think i'll pull the hood off and the cowl piece and see if the hinges themselves can be adjusted. I don't think I've ever had a hood fit this poorly. I could cheat it by shoving the front clip over toward the passenger side but then my bumper won't look centered.
Bumper is all welded up with the exception of the tube caps out on the ends and whatever I decide to do with some side bracing.
Only thing really left to be done in the front for fabrication is get the receiver tube welded in and get the air intake done. Plenty of wiring to be done up as well as other things like that.
I think its about time to get a replacement box side and start getting the box mounted to the cab.
