Are you going factory location with the Steering box?
I think a switch on the back to turn it off would work a lot simpler then figuring out a clutch. Turn it off and it would not drag, if that is what you are worried about.
Would have to be a big switch though![]()
The clutch would be simpler and easier then a belt idea.
Has anybody ever put an AC type clutch on an Alternator?
Wouldn't de-energizing the alternator coils do the same thing? Basically disconnecting the "energizer" wire via relay would do it. And even with a a/c compressor you are still turning a bearing. So an unenergized alternator would be about the same as what your talking about anyway.
That's a lot of money for just 205amps... Have you looked at mechmans?
Yeah if you already have it I understand but mechmans are that price for like 300ish amps last time I checked and they're the same deal with the off idle iirc.
this truck....was it being pushed or towed?
Did you mean Bretts truck?
