That sounds right. How else are they going to get those monster tanks in there? Probably will just stay with the saddle tank set up. Doing the inverted inboard shock kit on a 2wd seems a bit on the silly side90 burb I had was outboard shocks just like a k5
.I was getting the measurements off of an CUCV Blazer tank. How much of a difference is there in the front to back measurement?What size blazer tank did you try? 31 gallon or 26?
I'm not sure on the size difference. I was just following a guy on Blazer Bash with the 26 gallon tank and noticed it was quite a bit narrower than my 31 gal in my diesel blazer.I was getting the measurements off of an CUCV Blazer tank. How much of a difference is there in the front to back measurement?
Thanks for the insight. I'll check into it.I'm not sure on the size difference. I was just following a guy on Blazer Bash with the 26 gallon tank and noticed it was quite a bit narrower than my 31 gal in my diesel blazer.
I thought the Dana 70 dually axle was wider than a SRW 14BFF?You can run any wheels you like on the back can`t you? The fronts should just be adaptors that you could take off and run regular wheels on.
I think....could be wrong.
I know a guy here in town that has three dually chevys, one the brake backing plates are right up against the u-bolts and the other two have about 4" between the backing plate and the u-bolts. Sorry just googled it and answered my own question. His dually with the narrow rear axle must be a chassis cab truck, I guess they have a narrower rear axle and the regular pickups got the wider dually axle. Get a WMS to WMS distance for front and rear and see what would be the easiest to do to make single wheels work if you really want to go that route. I'd keep it dually other that you gotta buy 6 tires vs 4.Sorry, I missed the overall width part - an SRW 14 bolt is around 69" WMS and the (pick up) dually D70HD should be 74" WMS.
